racer x suspension
dadnjesse
racer x suspension - 09.05.2007, 10:23 PM
Does anyone know where I can get 16mm outside diameter by 6mm inside diameter, that will fit the Unlimited Engineering Racer X steering knuckles, Mike does'nt have them and niether does Unlimited Engineering!
09.05.2007, 10:30 PM
I assume you mean bearings? You could try this site: http://www.bocabearings.com/main1.as...ksearchbearing
Or this site: http://www.avidrc.com/shop/?action=category&id=1
dadnjesse
09.05.2007, 10:35 PM
yes I did mean bearings, thanks
dadnjesse
09.05.2007, 10:41 PM
Is the first number the inside then the second number the outside and the third the thickness?
09.05.2007, 10:55 PM
The smallest is usually the thickness, the other two are self-explanatory.
coolrunnings
09.06.2007, 02:41 AM
I use acer and boca.
