Motor Mount for 1/7th HB Lightning?? -
09.22.2007, 09:56 PM
Does anyone know if the HB LSP motor mount will work with the HB 1/7th scale onroad Lightning? They share the chassis and other parts, but the Lightning uses a two speed center gearbox instead of a center diff? The Lightning's center gearbox appears to use the same diff bulks as the LSP.
Not sure how you'd get two pinions mounted on a elec motor though, but you may not need the two speed due to difference in elec vs nitro anyway. Just curious, thanks!
