Originally Posted by tashpop
if i was using the trx system, id stick with the trx's motor. i don't see any benifit using the mamba motor. i think a better setup would be to use the mamba max esc and a feigao motor to keep cost down, or a better motor if money allows.
wasn't planning on mixing motor and esc...was planning on using either the mm/5700 or trx system
thanks for all your input i might opt for the feigao setup cause the cooler the motor the better performance
