mgm to motor connection
canatax
mgm to motor connection - 12.18.2007, 01:56 PM
i feel stupid!!! i got my mgm controller today and my 9xl motor the wires on the mgm are all yellow and the ones on the motor are all black i know the middle one on the motor goes on the middle one on the controller but what about the rest of the wires does it make any difference???? thanks
wallot
wallot's Avatar
12.18.2007, 02:07 PM
:D it does not matter how you connect the wires and if motor rotates oposite direction than you wish just swap two wires - it's in the BL faq
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
12.18.2007, 02:51 PM
And if the yellow/black mismatch concerns you, a little heatshrink will fix that...
david lamontagn
12.18.2007, 04:34 PM
Yes Rene, content que tu es recu ton MGM!!!
Like others guys tell you, the wire connection between the ESC and motor have not importance, the only think that can happen, is the motor rotate in the wrong direction, so you have just to switch 2 fo the 3 wires.
canatax
12.18.2007, 04:46 PM
thanks guy's i will try that...
