G3R steering question
v8srslo
G3R steering question - 12.14.2007, 10:11 PM
has anyone had an issue where you can turn all the way to lock one direction but not the other due to the angle of the turnbuckle rod getting greater till it binds on the servo horn should i be using something other than stock servo horns
i am only using one servo and have tried and tried to adjust the horn position with no luck is the chassis supposed to be straight or bent like the stock revo mine is straight and the steering doesnt quite line up like it did on the stock chassis
another question what bag was the spacers supposed to be in that the little carbon piece bolts to over the rear shocks i have the carbon piece but no spacers to mount it to
thanks in advance Rich
entjoles
12.14.2007, 10:50 PM
i tried this and it worked ok, but i now have the servo arm mount notched , not as smooth as i would like but it will go almost from lock to lock, ill try to get a new pic in the next day or so
first way i had it mounted
v8srslo
12.15.2007, 06:55 AM
cool thanks atleast im not the only one I was starting to thing there was something i was missing
