FLM steering linkage-help
mkrusedc
NeuMaxx
mkrusedc's Avatar
FLM steering linkage-help - 12.24.2007, 07:17 PM
I guess it is time to upgrade my steering linkage. I am putting a FLM chassis on my E-Maxx and just found out that the OE chassis has 2 plastic posts that the FLM chassis doesn't. This seems noobish, but what do I do? If the answer is upgrade, what linkage do you recommend?
Thanks,
Mark
wallot
wallot's Avatar
12.24.2007, 09:20 PM
you can get proline steering of the ebay or UE steering. but if i remmember correctly FLM chassis comes with two spacers to be used with the steering and they work like those plastic posts on the original chassis.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
mkrusedc
NeuMaxx
mkrusedc's Avatar
12.24.2007, 11:58 PM
Thanks, DickyT found them and is sending them Wed.
Duster_360
12.25.2007, 01:36 AM
wallots exactly right - the two round alum tubes that came with the chassis replace the stock plastic strg spacers.
I used a alum set of arms made by powerline. The plastic bellcrank on the proline set has a reputation for cracking and not lasting. This is the set I used on mine -
http://www3.towerhobbies.com/cgi-bin...&I=LXUL71&P=ML
mkrusedc
NeuMaxx
mkrusedc's Avatar
12.25.2007, 02:01 AM
Thanks Duster.
Serum
Serum's Avatar
12.25.2007, 05:27 AM
If you can hold your breath a little bit longer, wait for the new e-maxx to become less rare..
They use a cam-shaft type of saver too, and it will cost ~10-15 bucks.
mkrusedc
NeuMaxx
mkrusedc's Avatar
12.25.2007, 11:37 AM
Since I have been down for so long I will run OE until it breaks and then see how the 3905 linkage has held up. Thanks everybody.
