how do i make this work
raptor50
how do i make this work - 01.05.2008, 02:12 PM
here is what im talking about.. hope this could help me..OK,, I dont know why its not working but here what I did.
Im using 2 2S 4000 to make up 1 4S in series.
I did what was told to me and nothing works now.. I took out the red wire from the esc and put that into channel 2, and bec into channel 3. Now, nothing works. Before when I took out the red wire, I put the esc plug on channel 2, and bec on channel 3 plug, and everthing worked except that i didnt know where to put the brake servo wire. When I got the Bec, the cover showed to put the esc into 2, and the bec to 3 w/o any ommission of the red wire in channel 2. When I look into CC website, it shows to take out the red wire in the ESC plug.. Now im confused.. here are the pics..
any help is appreicated.. thanks,
ID:	3713   Click image for larger version
ID:	3714   Click image for larger version
01.05.2008, 02:22 PM
What exactly are you trying to make work? Pictures are nice, but sometimes more words helps too.
From what I can tell, it looks like you are trying to figure out how to wire in a UBEC?
raptor50
01.05.2008, 02:37 PM
here is the tread that i have questions about..
http://www.rc-monster.com/forum/showthread.php?t=9371
david lamontagn
01.05.2008, 03:42 PM
Ouffffff Look like the hair of my wife (or girlfirend, hein Lincpimp) after a hard bedbashing session
david lamontagn
01.05.2008, 03:50 PM
OK on your pics, all seam to be OK, but please, ISOLATED the red wire, if this wire touch to your heatsink controller... bye bye the internal BEC!!!
raptor50
01.05.2008, 04:31 PM
I will isolate that, but nothing works.. i tried this b/4 and nothing works.. is my bec a dud?
david lamontagn
01.05.2008, 04:35 PM
OK you use a Futaba radio, have you reverse trottle on your chanel 2 (in your Tx programation)??
Go in your Tx programmation and at the option -trottle REV- put it to ON.
raptor50
01.05.2008, 04:38 PM
right now, I think i have the throttle in rev. should i put it back to normal?
Matthew_Armeni
Matthew_Armeni's Avatar
01.05.2008, 04:41 PM
Did you connect the bec to the esc power leads? If you're still stumped do you have a rx pack you cann throw in and try that instead of the BEC?
  Send a message via AIM to Matthew_Armeni
01.06.2008, 12:08 AM
Ahh Bedbashing, do you use a baseball bat?
Eh, you hoser? He's a canadian eh!
raptor50
01.06.2008, 11:20 PM
I finally got it to work!!!!!!!!!
Out of all things, it was my receiver. I tried everyting i was told and i just changed the receiver and voila, it cured all the prob.
I was using a PCM receiver so I dont know if that had anything to do with it. mabye it doesnt work on PCM or my receiver is damaged. I switched to regular FM receiver and all works now.. Use mech,. brake, turned off the brake on the motor etc. Now I just hope my 5S experiment would work. so far its holding up.. Thanks for all your advise..
