Ok, found the conversion info.
http://www.eaglesviewaerial.com/revoelectrickit.html
I like the motor mount, and may give it a try, along with the speed control mount. Most likely will use the tekno battery tray, and will run dual steering servos, as that is what I have.
Motor will be a hacker c50 13l and a quark 125b on 5s lipo. Sound do well as it is almost the same as my emaxx setup, cave for the maxx has a 15l hacker.
Gearing at 17/40 with the tranny locked in 2nd, and buggy ratio diffs gives me right at 40mph.
I will try out the center diff, and see how it does with the 50k traxxas diff lube.
I will post some pics of the tranny mods, as they are different from the others that I have seen.
