Setting a Failsafe on BL Setup -
03.27.2008, 02:58 PM
This maybe a stupid question, but when setting a failsafe on a motor braking bl setup should'nt you just use netrual as the failsafe throttle setting? If you use full brake failsafe setting like with a nitro on a bl setup won't it just go crazy in reverse when you lose the signal?
With motor brakes, set the failsafe to go into neutral or it will go "crazy in reverse" like you said. If the failsafe is built into the radio, you could also set the steering failsafe so it would coast in circles until it stops (good if you happen to be going downhill )
With mechanical brakes, I would set the failsafe to about 75% brake, so that the vehicles slows quickly (but not lock the wheels).
lol...well I have the spektrum dx3r and I held full reverse setting it ...like i always did with nitro ...and I lost the signal on my e-revo ..omg it flipped going in reverse shot into some bushes running all out thought I'd blow my neu or mgm but when i got there motor and ecs were barely warm...sitting here I figured it was my failsafe setting...lol i am an idiot ...lol
