You will need a hardened pinion gear to last any length of time on a steel spur gear. The steel pinions I have can be case hardened(I may try to do a few of these myself in the near future). Without treatment, they only last for a handful or so of battery packs.
Welcome to the forums, also!
Thanks!:D ya i probably wont do a steel spur its much cheaper to replace a $5 dollor spur then a $10 dollor pinion plus the down time ill have to wait for it to arive. thanks for the reply
Ja, steel spurs are unwise, IMO. I can imagine the metall filings wound be annoying, too. This is something for nitro cars, at least they have no strong magnets around.
I was running a steel pinion/spur, that snapped the shaft of my Hacker C50.
The teeth on the pinion parted company, and jambed up in the spur...............I found out the hard way.....:o
Mike, can you get the Ofna Ultra LX centre diff that takes those 51t plastic spurs ? and can you get the Delrin spur to fit aswell ? if so i'd like to order one please.... ideally i'd like the centre diff, the diffmount hardware & atleast 2 x delrin or plastic spurs...
