I have just finished my brushless 1/8 buggy (described in another post). I now have two 1/8 scale buggies of the same make, one nitro and one brushless. And now I am wondering which is fastest around the track? Well if the weather holds up I will take both buggies out to the local track and make some timed runs. If everything works out I will post the results. Which one will be faster? You choose..
Specs:
Buggy 1 = Kyosho Inferno 777 SP2
Engine = OS V-Spec .21 VZB with OS 2050 tuned pipe
Wheels/Tires = Kyosho Orange spokes, Proline BT (rear) CF (front)
Futaba FASST rx
Fuel = Sidewinder 30%
Gearing = 46T spur, 13t bell (stock alloy Kyosho shoes and 1.0 springs)
Shocks = CEN 16mm Big Bores with RMV progression med springs.
Brakes = Kyosho special semi metalic pads and precision ground rotors.
Buggy 2 = Kyosho Kanai III
Motor = Feigao 8XL
ESC = MM with fan with remote UBEC
Wheels/Tires = Kyosho Green spokes, Proline CF (front/rear)
Futaba FASST rx
Battery = Maxamps 4s2p 6000 mah
Gearing = 46T spur, 12T pinion
Shocks = CEN 16mm Big Bores with RMV progressive hard springs
Brakes = Mechanical, Craddock fiber rotors.
