Medusa 36-50-3300 Vs. Ammo 36-50-3300
Buzzsaw46
Medusa 36-50-3300 Vs. Ammo 36-50-3300 - 04.06.2008, 02:54 AM
I've been thinking about building a nice brushless Maxx for a few months but had been waiting for the Monster Maxx(like everyone else).
About three weeks ago I decided to just get a new 3905 to play with stock till the new ESC hit the streets. Thinking I would need 2000w to get the performance of my Big block T I didn't figure the MM would handle the power I desired.
After reading a few posts of others planed setups I decided to give the MM a try with some small high KV motors I had on hand.
I started out with a Hacker C40-8L on 4s A123 with a 15t pinion. The motor and ESC ran happily with this setup and it had great accelleration but just couldn't pull enough gear(19T) to reach the speeds I was looking for.
I had the Ammo in my converted NMT so I figured what the heck, turn the shaft down and use the 1/8" pinions I had and let the testing continue
I started out with the Ammo on 4s and the 15t pinion and it was a dog, popped in the 19t and top speed was ok but it wasn't very quick out of the corners. Switched to a 5s2pA123 pack with a 13t pinion and the motor started coming to life, but was running a bit hot. Tried out a 15t pinion and speed and torque were awesome but the motor was getting HOT(no heatsink yet) went back to the 13t for a run and the motor siezed up the front bearing, and got very HOT. Replaced the bearings with some I had on hand I think they are ultra seals?? Ran it again temps still went real high and I was thinking I might have de-magged the rotor when it siezed up. So I started looking for an afforable quality motor as a replacement. Found a few threads about the Medusa V2. Being familiar with Medusa from helis I decided to try one out.
In the mean time I picked up a heat sink for the Ammo and seem to have the temps under control now, maybe. Needs some more testing yet.
Any way some pics of the test rig.
I had porblems with my temp sensor on the first run with the Medusa on 13t today but temps never went above 100f. Felt less powerful than the Ammo with the same gears
Fixed the temp sensor for the 14t run. Temps rose to 114f after I powered down the ET(I have an MIP onboard on it right now also to keep an eye on the temps)Power was at or a bit better than the Ammo on 13t now.
I have a few logs from the Ammo before I put on the heat sink and installed the cooling duct so I want to retest that motor once I find the limits on the Medusa.
The next run will be with a 14t pinion and a 65t spur, followed by 15/68, and possibly 15/65 if it's not building up to much heat. Future testing will log the temps on both the ESC and Motor also but wont have RPM
In the end I'm almost happy with the power I'm getting on the 14/68 gears, wouldn't mind just a touch more top speed, so it seems I only needed half the power I thought I would to be happy.
As to what it takes to make me happy as a basher I like enough torque to pull wheelies at 10-15mph and enough top speed to jump the two lane gravel road in front of my house. These two goals were met with the 14t pinion, I still want just a touch more
Stay tuned to see how the $35 Ammo($50 with the new bearings) stacks up against the $110 Medusa.
BTW, I seem to remember reading that 4 pole motors should have about 15deg timing on the ESC, I'm running the default 10deg on the MM and have noticed a few quirks running the Medusa at low speeds, couple times it sttutered a bit and once it seemed to hit reverse then buzzed, I let off the trigger almost instantly and it drove away fine so I'm not sure what happened??
