Revo Battery upgrade. A123 cells?
Sammus
Sammus's Avatar
Revo Battery upgrade. A123 cells? - 04.25.2008, 01:18 AM
Howdy, I'm sick of my cheap sh!tty chinese lipos, plus I had my revo over geared. I was running 6s 4000mah rated 20C constant 25C burst with a Feigao 11XL. The packs were good capacity, charging to around 4200mah every charge, but at the same time at 1C charge they hit the CV part of the charge pretty quickly and stayed there for a few hours and about 25% of the capacity before finishing - something I heard was a sign of poor quality cells.
Not too sure of the battery ratings, but my revo was geared 16/38 and had some incredible uncontrollable top speed that I really dont need. So basically, I was thinking I'm definitely gearing down (maybe 14/38 or lower) and also want new batteries.*
I didnt get a whole lot of runtime from the packs I had. Due to the massive amounts of heat generated I never ran it for longer than about 5 minutes, but I only got 2 or 3 of those runs in before it flattened.
Now, I was thinking of going 7s A123. due to the revo's small chassis I can only really fit a 7s1p pack on there. Will 2300mah give me pretty piss poor run time if I keep it geared properly (probably not more than 35mph)? I mean 10-15 minutes would be good, but I can't help but thinking I'll invest hundreds of $$ in these cells then wind up with 5 minute runs, 15 minute recharges.
It's either that or fork out big bucks for a couple enerland 6s 5 or 6Ah packs.
Anyone had experience running 1p A123 packs? Or perhaps any pics of layouts of 12 or 14 A123 cells on the truck?
Also, anyone elses gearing experiences would be good too (ie what gearing or geared for what speed, what motor/esc and batteries, runtimes, how hard you drive it etc) - and please, no penis size comps here guys, I want true honest opinions of how your trucks are running
Cheers
*The reason I havent tried this simple gearing change yet is because my batteries got all puffy and boiling hot from use in the revo and in my rustler with top speed gearing for out in the sand. Hence the need for new batteries as well!
