New maxx chassis
coolhandcountry
coolhandcountry's Avatar
New maxx chassis - 10.03.2005, 01:24 PM
I was thinking about a new chassis design. I want to mount a center diff on my chassis. I was thinking of making a new chassis for this. If I take a 3-4 mm sheet of aluminum. Make a bottom plate to run from back to front. Skids made in. Make a top plate 2-3 mm aluminum to connect where the top plates hook to the bulk heads. Have the center diff inbetween the two. Do you think it would be strong enough? What about weight as well?
Peace!
Country
Help support the
Rc-Monster
Buy here
dabid
10.03.2005, 01:42 PM
You could always just do it truggy style and get rid of the skid plates altogether, there was a chassis kit for the T Maxx that I remember seeing a few years ago that they did that to.
maxxdude1234
maxxdude1234's Avatar
10.03.2005, 02:09 PM
Providing you have access to a CNC milling machine and are pretty decent with CAD software, you could do a good job. Providing you use decent quality material and you use some good chassis braces, it should be strong enough.
or
http://homepage.ntlworld.com/ryan.coombes/emaxx.htm
Do what he's done....the easier option.
dabid
10.03.2005, 04:14 PM
I've seen his flame Jugg's before, just plain nuts. The little gif animation in the middle of the page is also his avatar here, just can't remember what his name is.
rchippie
rchippie's Avatar
10.03.2005, 04:27 PM
HI COOL !!!
What your looking for is a jt racing chassis. It has the lower chassis & skids as one peice. It also has the top plate, and uses a center diff instead of tranny. It uses the fr & rr clip of a maxx for suspenion. I belive it was designed for a ofne diff from the monster pirate.
REAL MEN RUN BRUSHLESS
maxxdude1234
10.03.2005, 04:40 PM
his forum name is candyman, can't remember his actual name....
Papa
Papa's Avatar
10.03.2005, 04:53 PM
UE and Dace produced thisdUEce VBS4JT kit. Sounds like what you have in mind.:D
rchippie
rchippie's Avatar
10.03.2005, 05:50 PM
Papa i forgot about that one. The only draw back to using that chassy is you have to have VBS. If he gets the JT chassy, which theUE & DACE chassy is molded after he wont have to get the VBS. He can save alot of COINS:L: .
Papa
Papa's Avatar
10.03.2005, 06:24 PM
The chassis itself represents only a small portion of the Kit cost. The big Dollars are for the BEAUTIFUL VBS. If he picked up a extra front and rear skid he could switch the whole suspension assemblies onto a Gmaxx chassis or something else if he desired. The chassis peices top and bottom are available individualy and they might work with his existing F/R assemblies with minor mods?
coolhandcountry
10.03.2005, 06:41 PM
Maxx dude You are talking about ryan coombies. I emailed him today. I don't want the motor and diff to be that high in the air. I know what I want just not sure on getting it there. I have the gmaxx chassis now. Made the bottom front skid for it with the top piece to. I don't have acess to a cnc. I thought about using the emachine shop. I want the chassis to be about as long as the one I have now. It is 60mm longer than a gmaxx. I want something like the duece but a little different. Any one has a better pics of the duece. I like to see the underside and braces. Thanks everyone.
Peace!
Country
Help support the
Rc-Monster
Buy here
Papa
Papa's Avatar
10.03.2005, 06:51 PM
I tried to get the pic for you, no luck. Here is a different look.
coolhandcountry
10.03.2005, 07:05 PM
Do you happen to know the thickness. It is the general idea. Just want it for emaxx form.
Peace!
Country
Help support the
Rc-Monster
Buy here
Papa
Papa's Avatar
10.03.2005, 07:09 PM
I wish I could help you with the dimensions. They have a good responsive forum over there. Give it a shot.
coolhandcountry
10.03.2005, 08:04 PM
Just like to know so I don't wind up with a weak chassis. I may set down and start. I not in a hurry so. It will all work out. Thanks papa.
Peace!
Country
Help support the
Rc-Monster
Buy here
Serum
Serum's Avatar
10.04.2005, 01:19 AM
Ahh.. Ryans truck!
Promod did a centerdiff too, he made one that sits a bit lower, because he removed the two upper praces from the G-maxx chassis..
Ryan doesn't use a diff, it's a slipper. a 42 tooth spur would fit nice between a g-maxx chassis though.
