I borrowed the MM and 8XL from my E-Maxx to test the E-revo...I was able to mount a 5S2P A123 cells, a temporary mounting for the ESC with the radio box was mounted on the reverse titan location..
Used a 22 tooth 32pitch pinion and default Spur
After hours of modding the chassis to fit all those in and calibrated the MM to the Traxxas TX Radio...I made an unloaded test run like I always do, basically truck hanging and all four tires are free to rotate. Half throttle, ok shes fine then a 1 sec WOT, i heard a banging noise....saw the front wheel free spinning and axle is bangin'. it got broken on the tip.must be an unlucky day.
sad to say she wont be takin' dirt today
Any suggestions on a replacement axle, I know there are tons but hoping to get your Ideas...
Thanks,
Jeff
