im running 4s with a 9xl with a 20t pinion and a 49t spur, the esc is 118 degrees, the battery is 108 degrees and the motor is about 160. to lower the temp on the motor would i put a pinion with more teeth and a spur with fewer teeth? or is it the other way around
or is 160 for the motor fine in the first place
thanks
IMO 160 degs is as good as it gets for a Feigao (the temps for the battery and ESC look good) but if you want to reduce resistance against the motor you can reduce the pinion size and/or increase the spur size
