Mod 1 spur for e revo
luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
Mod 1 spur for e revo - 07.17.2008, 09:08 PM
Hi guys is there any way i can buy a spur gear for the e revo not the 32 pitch cuz i have lots of 5 mm pinions for my mod 1 ofna spur gear that i used in my grollamaxx tranny thanks for the help what about this http://www.rc-monster.com/gears.php?pg=2or else where can i get them
Brushless Jammin Truggy on NEU 1515 2.5 D on Monster mamba max with maxamps 5000mah 6s Lipo
Gorillamaxx Revo CF version on Mamba maxx ESC with NEU 1515 1Y on Maxamps 4s 8000mah Lipo
07.17.2008, 09:17 PM
What is the bolt pattern? The nitro Revo (mod1) and Jato (32p) use the same bolt pattern (3 hole); I can't imagine Traxxas would change it for one vehicle, especially since most of the newer vehicles use the Revo-derived slipper setup. The only trouble you may have is finding a ratio that will work. AFAIK, the Revo spurs only go up to 40T, which limits the pinion selection. Just do the calculations to see how things work, and if the ratios work, you have nothing to lose by trying one out.
gixxer
gixxer's Avatar
07.17.2008, 10:40 PM
I use the nitro 40t spur on my e-revo with a 17t pinion. I dont think you could go much lower with out modding the motor mount. Maybe down to a 15t.
From what I have read you can mod the mgt spur fairly easily to fit the e-revo. That will give you some more gearing options.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
luvsrc
luvsrc's Avatar
07.17.2008, 11:26 PM
thank you
