Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
OFNA Ultra GTP / MBX conversion
OFNA Ultra GTP / MBX conversion - 03.13.2008, 02:23 PM
So I had a MBX buggy sitting around, and decided to convert it to a GTP on road car. It was not much good as a buggy, so I figured that it would do better as a road car.
Purchased a new front bumper and body mounts for the gtp, fit great, as the mbx and gtp share the same chassis, etc. I made an L shaped mount for the KB45 10l out of some 6061 al angle. Bolted it to the rear center diff bulkhead, and left enough of the L portion to screw it to some existing chassis holes. I also reused the upper rear brace I made for the buggy, and mounted the ccbec and the mm to it. Center diff was replaced with a solid center drive with the 51t plastic ofna spur gear (all stock gtp dirt oval parts).
Battery tray is designed to hold a pair of 2s2p emoil (drill lipo) cells. I have my trakpower lipos in there in the pics, artfully taped to fit the tray as it is too long for them. The emoli cells did not seem to have the punch and top speed of the trakpower lipos, despite being 6000mah. They must have a lower c rating, probably more like 15c.
Pinion is a 20t, got it from sdp-si. It is mod1 and has a 6mm hole, so I did not have to mod the KB motor shaft. Nicely made pinion, not hardened though, so it is only good for plastic spurs.
Only compaints so far is that the shocks have too much travel. A true gtp has shorter shocks, and I have a spare set of revo shocks, so I may have to make them work. The extra travel causes the body to catch the ground under hard braking and cornering. I was going to limit the travel of the stock shocks, but I figured that the revo shocks would be about the right length. Plus the stock shocks are crappy.
If someone else with a GTP (Briang?) could measure the length of the shocks at full extension it would be a great help.
Now for the pics!
