Would the Medusa 36-60-1500 be a good 6S motor?
sikeston34m
sikeston34m's Avatar
Would the Medusa 36-60-1500 be a good 6S motor? - 08.01.2008, 10:13 PM
Like the Title says, a good question here.
I'm looking for a kickass motor for my New E Revo. Together with the Monster Mamba, perhaps we shall go where no man has gone before.
Perhaps into a zone beyond sight and sound.
The Twilight zone. LOL
What's the best gearing for this? I prefer the Mod 1 gears. A 40 tooth Mod 1 Nitro spur.
Finnster
KillaHurtz
Finnster's Avatar
08.01.2008, 10:25 PM
I would think def yes, powerful but not overpowered.
08.01.2008, 11:27 PM
It does reasonably well in my hyper8. I have that motor and the 1600 kv version. I will say that some sort of heatsink is a good idea. I plan to gear the 1600kv motor down and run it on 6s.
Although most seem to think that a 40k rpm max is a good idea, higher end motors seem to work well closer to 50k rpm. I have run a variety of motors that high. Usually 3000kv plus motors on 4s. Hacker c50 8l, Hacker c50 maxx, plett maxx with and w/o fans, nd a few others. Feigao motors do not like over about 35k rpms. I have a few more motors that I plan to use on 4s that will stay around 50k rpm max...
You should be ok with the 1500kv on 6s...
lutach
lutach's Avatar
08.01.2008, 11:31 PM
Yes, I run a 1521/1Y (1577Kv) with 6S in my BPP truggy. I also run it on 5S and did do a few 10S runs just because I was curious . BTW, I'm going to use lincpimp's B50-11XL (1435Kv) with 6S as well.
08.01.2008, 11:45 PM
I just got the c50 11xl in the mail. I may run it in my savage on 8s... May produce a bit more power than the 14xl feigao. I will most likely put it in the hyper st with a MMM on 6s...
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
08.01.2008, 11:55 PM
Not sure if this is any help buuuuuuuut......
I ran a 10L in the Hyper to start, really didn't have the kick I was looking for. Switching to an XL can really made all the difference in the world. I guess where I'm going with this is that I think maybe the 60mm can might be a bit short for your application? Of course, I have no experience with medusas, so take that with a grain of salt! All I know now is that the 10XL is a monster in there.
asheck
08.02.2008, 07:26 AM
IMO a 60mm Medusa is alot better then a xl motor.At least comparing a 2000 to a 8xl.It has more torque,speed,and runs cooler.I have the 2000 in my Erevo and the 8xl in my 3905.The medusa does just fine on 6s,at least for as long as my esc can handle.
TexasSP
Something, anything, nothing
TexasSP's Avatar
08.02.2008, 03:36 PM
I ran the 1500 in my maxx and had heat issues on 6s. I had to gear down to 35 with it just to keep temps in check. It's a great motor but not enough for a monster truck in my opinion. I think asheck has better luck being a a more moderate climate. Temps in Houston right now are always high 90's to mid 100's so that could have been part of my problem.
Of course noting asheck's last sentence, the controller was the hardest to keep temps down on. This was all on an mgm 16018 however and I do plan to try it again once I get my MMM back next week. Right now I am sticking with the neu 1515/2.5d.
www.cubicle101.com
sleebus.jones
08.02.2008, 04:03 PM
You got it man. Right now temps are 99, which makes it kinda hard to shed heat! I watched the temps on my 10XL on my buggy yesterday, it was running 153 when I checked, and it was hot as blazes out there yesterday too.
sikeston34m
08.02.2008, 04:23 PM
What kind of heatsink/fan cooling did you have for your motor?
How about a pair of those 30mm wide heat sink/fan setups?
I wonder if that would keep temps in check?
I'm in Missouri. It's really HOT right here now too.
I plan on using Mod 1 gears. Probably something like 18/40 gearing.
asheck
08.02.2008, 06:14 PM
I live in KC.I'd say mine will stay under 150 at 85 outside.I just don't drive when it's hotter.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
08.02.2008, 07:44 PM
the 1300kv is a better motor for 6s
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
08.02.2008, 09:03 PM
I was wondering if the 1600 with lower gearing would be better in a heavier vehicle? That is what I plan to try in my hyper8. I am currently running a 1500 on 6s with 14/46 gearing. Thinking of going to the 1600 and running a 12-13t pinion. The 1500 was getting quite hot, but I have no heatsink on it and no cooling holes in the body.
sikeston34m
08.02.2008, 10:58 PM
If you do that, what are you going to do with the 1500?
big greg
08.02.2008, 10:59 PM
he doesnt get rid of motors, he inventories them! hello! lol
