Safe charging rate of a 4s 4800mah pack 25c -
08.16.2008, 10:24 AM
Right now I am charging the batts. at 4 amps. Could I go as high as 5?
I just want to be sure and not ruin a 130- battery. The batt. did not come w/safe charge rates on it so I have been charging it at 4 amps. I need to charge it today so i will up the amps.......thanks..
Thanks for all your input guys! I will charge them @ 4.8 max.
anyone know what the max rate on zippy-r? they look to me like polyquest failures (didnt meet the 5000mah or voltage requirement) so techincally could probably do 2c? not about to try but just another usual hijack
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
I would only charge those at 1c unless they say you can, I wouldnt try unless you would like to be the guinea pig
