BL Motor for Rustler
Raze ST Truggy
BL Motor for Rustler - 09.19.2008, 03:37 PM
Right now I've got a Ruster with FLM chassis and rpm arms. It's a bit heavier than stock, but very durrable. I've got a 5700mm combo in it right now that flies, but the motor seems to get hot 200F regularly (I may have already gottem it to hot but that is another story). I also have a modded mm with an external bec. That I'll be able to run 4S and 5S on if needed.
I want to get this thing to 80mph and I've seen a few do it with 4S and the velenion motor 3500kv I think. I'm thinking about the medusa motors 4800kv and the 3300kv or the velenion.
Does anyone have any sugestions to me for the BL motor that will get me to my goal?
I am hoping to gear for 80mph on 4S, and run it on 2S and 3S while bashing. Any tips are appreciated. thanks.
-Brian
brushlessboy16
brushlessboy16's Avatar
09.19.2008, 03:40 PM
1509 2d. or a 1512 1y or 1.5d
Raze ST Truggy
09.19.2008, 03:45 PM
Will those do what I'm wanting? How about size and weight comared to the medusa and velenion motor?
-Brian
B4maz
09.19.2008, 04:42 PM
-Brian
Sunny has the exact setup youre talking about He has hit 90.
http://s256.photobucket.com/albums/h...nyHouTX/faster
Raze ST Truggy
09.19.2008, 06:26 PM
I'm pretty sure that he was using the velenion motor and I'm wondering if the medusa will be a better option or not.
-Brian
azjc
09.19.2008, 06:36 PM
-Brian
it would be a much better option, the Medusa will have more torque which would enable you to gear up more with less heat issues
B4maz
09.19.2008, 10:10 PM
Yes the medusa is a much more powerful motor. Sunny has recently tested on 6s with the medusa and its veery fast.
Photobucket
Photobucket
Photobucket
Photobucket
B4maz
09.19.2008, 10:24 PM
-Brian
I think Sunny roasted his Velineon. The Medusa is a much better motor.
Photobucket
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
09.19.2008, 11:20 PM
+1 for the medusa, I have the 50mm 4800kv in a crt.5 and it pushes that around at 40MPH on 2s and only hits 125*F so I would think the 3300kv would do pretty good on 4s, I'm sure it'll get a bit warmer spinning faster but the crt.5 is 4wd and puts a good load on the motor. Best part is a Medusa is only a few bucks more than a Fiegao and around half as much as a Neu!
Raze ST Truggy
09.20.2008, 07:03 AM
Thanks for the advice guys. I'm going to get the medusa 3300kv and run it on 3-5 cells. What would you guy's sugegst for gearing? 3.17mm shaft or 5mm shart and convert to a revo sper/ slipper setup.
Right now I've got a stock Rustler trans case with a metal idler gear that seems to be holding togeather okay. Already ate the diff gear once, but am going to the steelringed version next time. Should I upgrade to the FLM aluminum trans case? thanks
-Brian
09.20.2008, 08:50 AM
I think you will need the FLM case - I just tried to swap to a mod 1 revo spur last night with a 7L with RCM heatsink - It wouldn't fit.
With no heatsink you might be ok.
PS I would go 5mm...
