BPP center motor mount and bearing support
lutach
lutach's Avatar
BPP center motor mount and bearing support - 09.29.2008, 04:45 PM
Hi everyone,
I like to thank Peter for an amazing job that he did with a custom center motor mount and bearing support for my BPP Truggy. Peter, I can't thank you enough for making them and I'll be sure to give you more things to make, if you up for it . The mounts are lower then the original ones so it'll help lower the center of gravity. I'm also going to send Peter 2 knew mounts so I can lower it even more and use a 51T spur. I would also like to thank Brian, the creator of this beautiful Bomb Proof Products conversion for sending me the file for the motor mount. Here are a few pictures Peter sent me and they will tell you guys everything about his skills.
