They put a non conductive laquer on the bullets and I'm not sure if the HS annodising is conductive but yes there is concern that this can cause a shorting of the phases and hence cogging / failure of the esc.
It may work day1 but the laquer may wear off and create a short...
There was rumour that in V3 the battery side bullets were being removed to create a bit more room for the HS
Patrick verified that in one of his posts recently. I was fine with the V1 having all leads direct soldered to the board and wished they had stuck with this. I just like to have a minimum number of connections to loosen.
I like the bullets at least on the motor side. Neu motors aren't ideal in the fact that they don't have solder tabs or regular wires. If they did, a single piece of wire for each phase and a connector at the esc cleans things up the most.
the castle mostets have long wires with bullets attached which is why the mmm has the females. With a mmm combo the only connections will be the ones on the mmm.
