Improve Deans Connector Grip
Improve Deans Connector Grip - 09.19.2008, 09:34 PM
I've heard some people complain that the Deans connectors are too small to grip effectively, and are therefore hard to connect/disconnect. You can yank on the wires, but that's not the best idea. Unless you want to move to a different connector type, you're kinda stuck. Not to mention changing over all the connectors you already bought and soldered.
There are other "psuedo-Deans" out there that have a longer grip area, but those aren't usually readily available at hobby shops like Deans are.
However, a little work with a glue gun can improve this. Not only that, but this mod also provides a little strain relief for the wires.
Step 1: The wire/connector
Step 2: Apply hotglue all around the wires right up to the connector. Don't add too much at once or it'll just drip off, and may burn you (trust me, it hurts). So, apply it in layers if needed. Since it will melt down somewhat, I make it larger than the connector.
Step 3: When cooled, get some heatshrink large enough to go over the whole thing. It's ok if the end overlaps the connector end because it will be trimmed later.
Step 4: With a heatgun, shrink the tubing all the way around. If the hotglue underneath looks lumpy, hold the heatgun on a little longer so it starts to melt the hotglue inside. Not too much though or it'll come out.
Step 5: Right away, hold the whole thing up by the wires. This will keep the hotglue from oozing out the end while it cools.
Step 6: Once cooled, trim the excess heatshrink on the connector end to clean it up. There may be some hotglue that oozed out here, but that ok because it doesn't stick too well to the Deans connector and comes off easily.
Now you should be able to grasp the connector easily. And the heatshrink shouldn't come off because the hotglue has bonded to the shrink inside. The only disadvantage to this is replacing a worn connector will probably be a PITA.
09.19.2008, 09:49 PM
Nifty, this forum needs a section for BrianG sticky how-to threads!
09.19.2008, 09:53 PM
Lol, it would be a pretty weak section since I don't post these things every day.
Sammus
Sammus's Avatar
09.19.2008, 09:55 PM
I buy mine from hobby city (yeah, not genuine, sorry :P) and the plastic is all ribbed, awesome grip :P
glassdoctor
TEAM FUSION
glassdoctor's Avatar
09.19.2008, 10:13 PM
Hmm... ribbed... nice.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
jhautz
jhautz's Avatar
09.19.2008, 10:42 PM
Seriously Brian. Where do you find the time to think these things up. I love it.
However, I just dont see me doing this on every connector I own. I guess I'm just too lazy and pulling the wire hasnt ever caused me any problems yet. I guess it could wear the wire out at the solder point, but I just look at it as I am making sure the solder joint is still strong after each run.
to make it...
or break it...
Silent...But Deadly
rcsammy
buggy beater
rcsammy's Avatar
09.24.2008, 11:32 AM
lol i always use hot glue on my deans, instead of heatshrink though. i find it easier
i also use the deans from hobbycity, very good grip
  Send a message via MSN to rcsammy
Gee
A Horse's Ass
Gee's Avatar
09.24.2008, 12:26 PM
"need... to... focus..... stay out of the gutter Gee, just walk away."
Thanks Brian. I like the idea. I have the problem with the heat shrink on my deans connectors getting pulled away or tearing from disconneting them. Now I have to find where I hid the glue gun. My brother went nuts with it last visit. Thought he could fix everything with a little hot glue. Scratch that a lot of hot glue.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.24.2008, 06:15 PM
Nice work, have to give it a try
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
09.24.2008, 09:34 PM
NICE.... I will have to put this on my " to do RC weekend list "
Thanks Brian for the tip..
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
10.05.2008, 10:48 AM
Now that's inspired, Brian! Might just have to use that trick on my Deans'.
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
10.14.2008, 12:12 AM
You could also make a diagonal cut about 1mm away from the meeting edges, which would allow just enough space to wedge a fingernail between the connectors. Just throwing it out there as another option.
Area 52 Ranch Raceway
T.R.C.R.
