how to install rc18t sway bar kit???
t-maxxracer32
t-maxxracer32's Avatar
how to install rc18t sway bar kit??? - 10.13.2008, 02:16 PM
hey guys i just got this kit and the directions make zero sence to me.
the only pic i can find on it is at atomic mods but i still cannot get it right....
anyone else have this on their 18t? with one decent pic i can figure it out...
thanks!
The Cow
The Cow's Avatar
10.13.2008, 02:41 PM
thanks!
Hello my friend
Sounds like you have made the same mistake I did unless you have the atomic suspension arms the kit will not work unless you tap holes in the arms.... I am no newb to fabricating and after taping numerous RPM arms to utilize them They honestly impeded performance pretty badly. I have spoken to a few people using them in conjuction with the intended arms and they where less then happy with them.
This is a pretty common mistake I know of more people that have them in the unused pile then the 2 I have seen using them
Hope this helps!
Heath
"from deep within the barn doors"
** COWRC.COM **
t-maxxracer32
10.13.2008, 02:55 PM
haha that would explain so much.
it looked like they wanted me to put one of the ends into the aarm but i was confused since there was no hole!
thanks cow!
this is what i ended up with
The Cow
The Cow's Avatar
10.13.2008, 03:28 PM
Purdy Cool! Have you tested it out yet?
Heath
** COWRC.COM **
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
10.13.2008, 04:00 PM
How do you like that 18T? I've wanted to get one for some time. Maybe I should have gotten one of them instead of a 1/8 truggy, lol.
:D
t-maxxracer32
10.13.2008, 04:01 PM
could not test that setup due to me needing a servo...
stupid ebay store is lagging on shipping
it would not be able to work very well anyways because the body hit the sway bar.. so it really couldnt move.
i drilled some holes in the arm and installed them the right way.
i really dont know how it will make a huge difference... but at the same time i dont think it can hurt anything. (other than the aarm... but my holes are in a good place i think?)
anyways i appreciate the help!
ill let you know how it goes once the servo its here!
have a good day!
The Cow
The Cow's Avatar
10.13.2008, 07:04 PM
I love the RC18... It is a great mini, has tons of potential although it does need a bit of work and there is a few kinks to address in the stock setup to make it a true performer Here is the link to my build http://forums.thetoyz.com/index.php?...%20exotek&st=0
And a few pics
Notice anything different about the suspension?
This is on the more extreme side but is a true 50+ mph mini
Dont get me wrong it is no 1/8 but it is a great R/C and the best mini IMO if you are willing to invest a few dollars into it.
have a good day!
Looks good my friend! post some thoughts once you got here going....
Good luck!
Heath
** COWRC.COM **
t-maxxracer32
10.13.2008, 07:18 PM
oh very nice you have the exotek chassis ya?
ive wanted to get one but instead of that i upgraded a bunch of different parts on my truck (screw kit tires tit turnbuckles n so on)
i as well like the 18t!
i will be purchasing a mini quake, NOW and from kulang so ill be able to compare it to others.
gtxracer
gtxracer's Avatar
10.14.2008, 01:52 AM
You moved the shocks to the inside.....why?
:D
MetalMan
MetalMan's Avatar
10.14.2008, 11:03 AM
That brings the weight of the shocks closer to the middle, which improves the center of gravity.
The Cow
The Cow's Avatar
10.14.2008, 12:24 PM
Hey guys....
My reasonoing was this... First and foremost I wanted to extend my wheelbase... By flipping the suspension arms I was able to gain an extra 1/4" on each set of lipped arms for a total wheelbase extension of 1/2". This made a huge impact in my high speed handling-stability-response! Secondly I run pretty chopped body's that most leave the shocks exposed.... I was tired of destroying my pretty shocks everytime I took a 40mph roll Sure I could have covered them up but I love the look
As you can see in the pics they were just asking to be destroyed in the previous setup
This took a bit of work to make work and alot of tuning and small little cant notice alterations to make work properly however when all is said and done it made a huge improvement in a veh IMO had little room left This would not make sence for those of you off road bashers but if you are a pavement pounder like me, a carpet or asphalt racer, or just like things low and fast this is a hell of a mod if you take the time to get the tuning locked in.
Just my 2 cents Thanks for the interest my friends and if there is any questions on the setup or the work involved to try it dont hesitate to ask!
Heath
** COWRC.COM **
