How do I re-calibrate Mamba Micro Pro ESC
FastXR
How do I re-calibrate Mamba Micro Pro ESC - 10.18.2008, 12:15 PM
Im sorry if this is a repost, hopefully someone will be kind enough to answer.
As the title says I just got a Mamba Micro Pro for my brushless Kyosho Mini Inferno and calibrated it to my Spektrum system per the instruction manual, however I had decided to switch model # on my TX at the last minute and didnt realize that the EPA settings werent set between 100-125 on throttle and brake. I would like to redo the settings, but I'm not sure how to do that, can someone help me out? Thanks.
MetalMan
MetalMan's Avatar
10.18.2008, 12:20 PM
Hold full throttle, turn on the ESC, when it beeps hold full reverse, when it beeps again put the throttle to neutral, and you're done .
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
10.18.2008, 06:29 PM
Yep, pretty much the same for all Castle ESC's
FastXR
10.18.2008, 02:05 PM
Thanks MetalMan!
Thats what I tried the first time, but I must have waited too long and it armed itself and just went to WOT. I tried again and it recalibrated just fine.
Thanks
MetalMan
MetalMan's Avatar
10.19.2008, 01:15 AM
If you're running 2.4ghz and the receiver/transmitter don't bind soon enough the ESC can arm before there's any signal to the ESC.
FastXR
10.19.2008, 08:04 AM
Yah I think that is exactly what happened, I did it again and it worked fine. Thanks again.
