Design Flaw...
Edumakated
Design Flaw... - 10.14.2008, 12:21 AM
So I have a v1 and a v2 that are still working. I also have a v2 that went up in flames that is currently at Castle.
It is pretty obvious there is a design flaw in how the board sits in the case. Every Monster I have owned has had the fan plug break off after a race or two.
I was performing some routine maintenance on my car after a race this weekend in which the monsters performed FLAWLESSLY. However, when I took the case apart on both I noticed that there is a little chip thingy that was crushed on both of my Monsters. It is obviously getting slammed around in the case. I am wondering if this is why the Monsters are failing.
Here are some pics. Both of these Monsters are working fine, but this chip obviously bothers me. It is the one with the 223d written on it. I hollowed out the bottom of the case and it has the padding in it, but it still doesn't seem to be enough to prevent the chip from slamming against the bottom of the case. I understand the v3s will have a little more clearance in the case.
Just some additional data for Castle.
