Project “X” Build 002 “The battle EVO”
TDC57
TDC57's Avatar
Project “X” Build 002 “The battle EVO” - 10.07.2008, 02:35 AM
I’ve got my next project LOL..
I'm thinking this would look killer mounted on my GorillaMaxx E-Revo
So stay tuned as I transform my prize build pro into a (Grenade launching) BAD ASS.. and with a range of 30’ that just doesn’t get any better..
Dimension : 7 3/4" Tall, 20" Long, 7.5lb
Range : 30 ft
Velocity : 300 fps
Grenade Cartridges:
The M48 Thunder Grenade has 5 bores that shoot from 1 to 50 6mm paintball pellets in one shot.
The M203 Thunder Grenade can shoot up to 10 .43 caliber paintballs all at once. Oversized .43 caliber paintball can be used to cap off the bore to increase shot capacity to 25 rounds.
The M68 Thunder Grenade is the loudest, the most powerful, and the most versatile of all of our grenades. The M68 can be used with 6mm, .43 caliber, and .68 caliber paintballs, and smoke simulation powder. The M68 has a yawning, hollow cavity that can hold 100 6mm paintballs, in conjunction with smoke powder to add a realistic scent. The bore can be capped off with a .68 caliber ball to keep the 6mm balls and powder in place.
Grenade Ammunition:
Grenade Ammunition:
6mm paintball pellets are best used with M48 and M68 grenade shells.
.43 caliber paintballs are best used with M203 grenade shells. They are also available in an oversized version use to increase M203 shell loading capacity.
.68 caliber paintballs can only be used with M68 grenade shells.
Nerf Rockets can be launched over 50 feet from our grenade launchers. The Nerf Rocket can be loaded in the bore of the Phantom, M203 and RIS M203 grenade launchers. The Nerf Rocket is propelled by discharging the M68 Grenade Shell. The rockets can then take out tanks and buildings in Milsim scenario paintball!
Scented Smoke Simulation Powder works with all grenade launchers to add a true battle field scent, and dramatic puff of "smoke". you just have to love this hobby!..
Before:
After:
TBD:…
Thanks for your time team and have a great one.
Shaun..
P.S.
Here is low res veido of it in action..
http://rap4.com/video/paintball_gren..._grenade_l.wmv
P.S.S.
As always I;m looking forward to hearing and seeing your comments on how I can top my "Battle Truck" build..
Nothing!.. Hahahahaaa..
