Looking for new Mini
Bronco
Looking for new Mini - 07.30.2008, 07:27 AM
Hi all,
As the titel says, I had an LRP Shark Factory Team (Vendetta ST) in mind but the CRT.5 caught my attention this week.
I have been reading here but would like to ask about some things :
- Is Jammin/Hong Nor the same car ? I mean quality wise (I know they are the same)
- Can one only buy RTR's or also rollers ? Do the RTR's come build?
- I have a MM + 5700 lying around, so I would also convert to brushless using 2cell Maxamps 6000 mah lipo's.
- What do you do whit the not used parts (engine, cluctch, ...) I would sell them ?
- Except for a motor mount, what else would I need ? Pinions (which) Spur (which) Spare Parts ...
- Is the new CRT.5 with PBS steering already available ?
- I see alot of lipo's put on their sides on the chassis. Is this the only option
- Does one really need the extended chassis to put in a 1/10 scales servo?
- Is the standard drive really up to brushless power ?
- What about steering slop/ wheel slop ? Is it an issue like it was for example with my Mini Inferno ?
- The center diff of the Mini Inferno had the issue of unloading to the front wheels. Is this also true for the CRT? Or is the power even to the front/rear?
I know these are alot of questions, but any answers/advice/comments/thoughts are welcome
Thanks in advance
