updated my MMM V1, now it's dead
gogglespaesano
gogglespaesano's Avatar
updated my MMM V1, now it's dead - 11.07.2008, 08:59 PM
I've been running my MMM V1, bought from mike on the orginal preorder, with no changes or updates until today. I figured I should update the firmware since they supposedly worked out the bugs, guess I should have left good enough alone. I ran for a couple of minutes and went to change the brake amount with the controller. Shut it off and went to turn it back on again....dead. No lights, no beeping, nothing.
Bummer. I guess the lesson here is, if it ain't broke, don't fix it!
Andrew32
11.07.2008, 09:11 PM
well you really didnt do anything wrong IMHO. castle said update it so....
gogglespaesano
11.07.2008, 09:22 PM
I just took the switch apart, turns out it's just a crappy switch not a firmware problem. Thankfully don't have to send it back!
pasan
I <3 RC
pasan's Avatar
11.15.2008, 09:15 AM
heh I had the same problem but the opposite, after I upgraded to 1.20; the damn thing wouldn't switch off, and I was like 'wtf? an MMM that refuses to switch off at the switch??" After a little more rocking it eventually worked. Broke out the contact cleaner sprayed liberally over the switch and it's fine now.
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
11.08.2008, 06:08 AM
Alot of swtiches have been going. Did you replace it with another switch or just wired them together?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
gogglespaesano
11.08.2008, 08:13 PM
neither, I took the switch apart and re-bent the metal contact plate. I was going to buy another switch, but couldn't find one that would fit properly, didn't look too hard though.
Andrew32
11.08.2008, 09:04 PM
a switch is a switch is a switch.
a single pole single throw of anykind would work. guess it comes down to how big it is or the style
Chapito
11.08.2008, 09:50 PM
Lost the Switch on my V1 two weeks ago. At least they're consistent.
e-mike
e-mike's Avatar
11.08.2008, 10:01 PM
sorry for your lost......very strange my v1 still more smooth and run cooler after the update...
D8t on juice!!
11.08.2008, 10:44 PM
I usually use an enclosed-frame style switch. Even though the CC switch is in a little plastic holder, dirt still finds its way in there. Plus, those switches tend to be a little on the chintzy side.
An easy to find SPST (single-pole, single throw) switch: http://www.radioshack.com/product/in...ductId=2062497
11.08.2008, 10:52 PM
I too use a switch like this for my esc's...no more worries!
11.08.2008, 10:58 PM
Note about the switches: There is a lower amperage 0.3A version, but I would stay away from it. Even though the ESC switch doesn't need the higher 3A version, the switch pressure is stronger and would have less tendency to bounce off when landing a hard jump.
