Review: TrueRC Hard Cased LiPos 5000mAh 2S 7.4V w/ TrueRC LVC w/ e-Station BC-6
rawfuls
roofles.
rawfuls's Avatar
Review: TrueRC Hard Cased LiPos 5000mAh 2S 7.4V w/ TrueRC LVC w/ e-Station BC-6 - 11.15.2008, 05:39 PM
Well, I promised a review, and here it is.
I got:
(2) TrueRC Hard Cased 5000mAh 20C 2S 7.4V 2S2P LiPo packs
Link: http://home.comcast.net/~truerc/read...eady_packs.htm (Scroll Down, no direct link)
(1) TrueRC 2S Deep Discharge Protector
(1) e-Station BC6
Link: http://home.comcast.net/~truerc/Charge/chargers.htm (Scroll Down, no direct link)
Included with the LiPos were: (Since I bought two packs, I get double of the things... of course)
(2) Deans Harness (4mm Bullet Connectors that plug into the pack, and the deans go to the ESC)
(2) Balancing Harness (4mm Bullet Connectors, and 1mm bullet connector for balancer port)
Included with the LVC (Discharge Protector) were:
A Harness, the connects the 2S balancer harness, to the the actual port of the LVC)
Included with the e-Station BC6 were:
AC Cord (For house use)
DC Cord (Alligator clips, for 12V use)
Alligator Clips for any kind of batteries (w/ 4mm bullets, to connect to the charger)
Packaging:
Packaging for the lipos were perfect. Signature confirmation, made it even more perfect.....Bubble wrapped, everything, just perfect! The packs would not budge, so the rough handling was nothing for the lipos.
Packaging for the charger (as I ordered this separately) and the LVC was great, once again. Bubbled wrapped, in the original packaging, in another box, and then was wrapped. Items would not budge while in package, so this was another plus.
Features:
LiPos:
Connections are in 4mm bullets (from harness to actual pack, through the hard casing)
Tough casing...
Harness made of 14-16GA wire.
Original Dean Ultras.
Charger:
4mm connections
AC Cord
DC Cord
LCD Display
Can charge
  • PB Batteries
  • NiMH Batteries
  • LiPo Batteries
  • NiCD Batteries
Load/Save Battery Memory
Can balance, fast charge, or normal charge all batteries
Voltage change
LVC:
2S Capability
Different voltage cutoffs
Button for easy use
LEDs for easy use
Usage:
Prepping and then using the LiPos is so easy! Just plug the red wire (+) to the red (+) female port, and do the same for the negative, black wires. Then, it's plug and play!
Using the LVC, you need the harness, the converts the equinox to the LVC. Plug the pack in their, using a custom harness you make.
The harness that I used is:
Use the balancing and regular set of harness.. Snip the balancing + and -, and just splice them right into the Deans harness. Voila. Plug these in, and, during use simply plug the pack into the LVC. You'll want to unplug the ESC's RX plug, and plug it into the LVC (make sure the polarities are correct! By using the manual). The LVC's RX plug goes into the ESC's RX position, and voila, there you are! Using the red button, you can change the Voltage of when the LVC shuts off.
For using the charger, it's as simple as it gets. You'll want to follow the whole manual, as it'll be way confusing if I tell you it. The manual is a GREAT English, and not engrlish like most manuals are written in. You need to set the intial functions for the charger, then everything goes from there! Everything in my setup, the LVC, the packs, and even the chargers are "Plug n' Play"!
Specifications
The packs fit every single car/truck I have.
The TT-01, the E-Savage, the EMaxx, and even the Evader EXT/ST pack slots.
But, for those people who want to make sure, over and over, here are the measurements.
Length: 5.30"
Width: 1.75"
Height: 0.45"
This is with the logo facing up.
BC6:
Length: 5.50"
Width: 5.50"
Height: 1.50" (At it's tallest point)
2.50" (At it's shortest point)
LVC:
Length: 1"
Width: 0.75"
Height: 0.25"
As you can see, everything is pretty small, and compact.
Everything is measured with it's logo pointing towards the sky.
Tips:
You'll want to make sure the LVC is on it's primary side, where the ESC can power up by itself, with one pack, if it's a 2 pack (like the ESavage, EMaxx) configuration.
Charger: You'll want to put this up on something, if you're charging on carpet. My dad is just....... he thinks of the worst, so he gave me a few aluminum boxes, to stash my stuff, in case, of the worst, which will never happen. >_>
Packs: Be careful not to drop these, although they are hard cased, you never know, better safe, then sorry!
Plug one connection at a time, do not
Bottom Line:
I think my setup was very affordable, for about $150 on packs, about 150 on the charger, and 20 on the LVC, for a total of 320, I think it's as cheap as it can get, but still get decent stuff that isn't cheap stuff.
Recommendations?
I would recommend this to an avid basher or racer, in less then a heartbeat. But if you're still new, you just got a vehicle, I would NOT recommend this setup. LiPos can be very dangerous if improperly used.
My packs have been in perfect balance, but if one of them gets out of balance, I will have a big issue. Treat these with even more care, than you would with a crystal glass, while tightroping.
Pictures
My carrying case, 20 bucks from Harbor Freight.
http://i53.photobucket.com/albums/g6...4/IMG_2323.jpg
BC6 next to my MRC 960
http://i53.photobucket.com/albums/g6...4/IMG_2324.jpg
Everything
http://i53.photobucket.com/albums/g6...4/IMG_2325.jpg
Closeup of what you need to do to use the LVC
http://i53.photobucket.com/albums/g6...4/IMG_2326.jpg
LiPos in their little pouch (from packaging, works great though)
http://i53.photobucket.com/albums/g6...4/IMG_2327.jpg
Closeup of the BC6 w/ AC and DC cords.
http://i53.photobucket.com/albums/g6...4/IMG_2328.jpg
Everything
http://i53.photobucket.com/albums/g6...4/IMG_2329.jpg
