Post pics of your electric crt.5!!!! Also your BL setup!
R00ST
Post pics of your electric crt.5!!!! Also your BL setup! - 11.19.2008, 11:50 PM
I am debating on tires for the crt.5 so I would appreciate a few pictures of your setups! Maybe one body on, one body off and one next to your other rc's?
I will add mine once I get the 17mm adaptors figured out and actually get to run the thing! ( still waiting to order parts..).
Also.. if your on brushless post your motor/controller/batt/gearing. If you know top speed and run time that would be cool :)
I will have mine done in a couple weeks so will add pics/info then. Planning on VXL motor, MM controller on 3s 5000 with varying tires, starting with 11 tooth pinion to see where I stand on gearing.
