I never do how to use to fail.
6s
1515 2.5
16/44
now RC8 gear up (20/44).
It moves with another 16018 smoothly.
I say only my mistake for various reasons.
Because English is not so proud, I cannot strongly say.
Only pay repair is made.
mgm email
Dear Kim,
ne clear which motor and setting you really use, e-mail bellow you wrote about NEU motors ???
In all cases, when you overload the motor, you can easy damaged magnets in the motor - you find this state also easy: current without load is significantly higher than nominal catalogue value, rpm/V is also higher and when you rotate with shaft by hand, you can find smaller force than with corect motor.
4 mm connectors which you use are no good choice for 160A power unit - these connectors have very bad parameters for higher current and can loss contact --> damage controller. We strongly recommend better connectors, for example MPJET 3,5 or better MPJET 5,5 or MPJET 6,0 (
http://mgm-compro.com/index.php?tid=...tors-mp-jet-60 )or equivalent.
Best regards,
Grisa
----- Original Message -----
masense3911@yahoo.co.jp
To: Ing. G. Dvorsky
Sent: Sunday, December 28, 2008 7:12 AM
Subject: Re: hello! my 16018
I bought it in January of this year.
It is not the thing which it sent a half year ago.
I have 16018×2.
I have 16024×2.
The motor is TEKNO 1,515 2.5
It is a new article.
It does not cut the motor wiring either.
The thing broken this time ran in MUGGY cheerfully.
I have not placed battery adversely either.
Would it be life soon?
Then there is not a way.
I do not do at all wrong setting.
RC8A photograph of the setting
http://www.flipclip.net/clips/masens...e5a0e1e2afea72
"Ing. G. Dvorsky"
wrote:
Dear Kim,
waranty is one year, but customer mistake can damaged controller 10 minutes after buying and no possible lodge a claim.
Your controller was here some month ago and was also damaged by your mistake (damaged current sense resistors for BEC etc.), this is no possible other way than your mistake (100%).
Now we don´t find component problem or assembly problem. All wrong components shows in first hours of equipment life, no after 6 or more month. I don´t know which connectors you use, which setting you use, your motor can has defect, reverse battery polarity is possible or short circuit on the motor cables. I am sorry, this in no under waranty.
Best regards,
Grisa
To: Ing. G. Dvorsky
Sent: Sunday, December 28, 2008 12:06 AM
Thank you for an email.
I waited for your email for one month.
It is too late.
I purchase my 16018 and do not pass for one year. (RCM)
I was testing BUGGY RC8 with NEU1515 2.5 in 6s, and burnt.
Become the problem; do not run.
Why does repair cost money?
Why is not it Product Warranty?
"Ing. G. Dvorsky" wrote:
Dear Kim,
your controller is very damaged (all power plates), repair is possible, but price will be the 90% of the new controller. I suggest you better solution - new controller with the best price (~60% price). TMM 16025 - 3s Car/Boat E-series with coolers and I can give you price 110 Eur + shipping.
Please let me know if this solution is good for you.
Best regards,
Grisa
P.S.: I wish you happy new year 2009.
To: mgm@mgm-compro.cz
Sent: Friday, December 26, 2008 6:35 AM
Subject: hello! my 16018
hi!
im kim.
I send ESC, and it is one month.
Then I never get an answer.
When does my ESC return?
Thank you.
My mistake which MGM says will be anything.
