Speed Pede Project...
Speed Pede Project... - 11.01.2008, 09:41 PM
Well my pede hasn't had much attention lately so I gave it a bit of a make over...
I think the motor (CC 1515 1Y 2200) is overkill but needed to run it in something - I can't get a MMM in there though as the motor wires aren't long enough so opted for a trusty MM.
I inverted the RPM bumper and added some lead to help keep the front end down. I think I may have to lose the wing but will see what happens... I checked and it looks like a revo 2.5 body that I have will fit pretty well if I lose the wing...
Any other suggestions?
Differential Ratio: 1
Transmission Ratio: 2.727272727272727
Other Ratio: 1
Spur Tooth Count: 40
Pinion Tooth Count: 20
Total Voltage: 18.5
Motor KV: 2200
Tire Diameter (inches): 4.1
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 2 : 1
Total Ratio: 5.45455 : 1
Tire Circumference (inches): 12.88 inches (327.17 mm)
Total Motor Speed: 40700 RPM
Vehicle Speed: 91.01 mph (146.2 km/h)
Estimated Adjusted Speed: 79 mph (127 km/h) - 13% loss
Effective KV Value: 2200
