Wondering what it is? I know they come stock with a 13-14t pinion (not sure which...)
I am looking for the ratio of the tranny and the "spur" gear size... It has a 3 gear tranny, and the "spur" is directly attached to the first gear in the tranny. Maybe it would be considered a 4 gear tranny, as it has a double reduction internally... Anyways i want an easy way to plug numbers into the speed calc so that I can determine what motors to use.
So Chip Cross seems to think a pair of 45t motors will be a bit better than the 55t motors, but with 7t pinions instead of the stock 13t pinions... That would drop the speed to about 5 mph, which is a bit slow for my uses.
In my Clod crawler, I ran 55t motors on 2s. I had a 10t up front and a 9t in back to help even out the infamous "Clod-stall". It had enough wheel-speed for everything I did with it.
Never should have sold that one. It was a great rig.
Could you please explain this "clod stall" phenomenon? Is it related to the dual motor arrangement? I have the Berg 2.2, so I'm a bit concerned.
Cold stall is when you are running at a certain throttle amount, both motors get the same voltage. Well if you are climbing the rear motor takes more load, and that voltage may not be enough to keep the motor turning so it stops. Only real way to help this is to run a lower pinion in the rear for more reduction, or run 2 seperate speed controls off of a stick radio independently. So you control both motors with a seperate sticks, and when you climb you give the rear a bit more than the front... That is how I understand it...
It's actually an advantage on some uphill climbs because the back wheels won't flip you over backward. It allows the front wheels to pull you up. You do want to have some control over it though which is what Linc was talking about.
Watch 2:08-2:22 of this video of my Clod. I was able to get up a near vertical climb that would be impossible for most shafty's I've ever seen/used. It was even more impressive in person than on the video. MOA crawlers are nuts, which is why Bergs are becoming so popular.
