in about 2 weeks i get all the stuff i need to finish my rc8 conversion.
im well be using the following
rc8
ae conversion
6s 4000mah 25c
mmm/2200kv combo
i dont know what i should do about gearing. i dont want it to over heat but i want it to have amazing amounts of power. like kill my nitro buddys. i think there cars are going about maybe 45mph.
also what kinda run times do you think i should be getting with the 4000mah 6s battery packs. im hoping for like 15 to 20mins.
With a motor that big in a Buggy you have plenty of room for gearing. A 13T pinion should put you up around 50 MPH, but you could go higher if you wanted. Hopefully those lipos have a good discharge on them because that big motor is going to draw a lot of current.
Sounds like a cool setup, But Id rather get a 4s setup with 6000mah capacity, and you should have killer run time and keep the MMM combo happy with lower temperatures.
AE Factory Team TC4 4c2p 6000 & MM 5700
Brushless Traxxas Jato MM 5700
SH Z-Car MMM2200/5s4000mah Turnigy Packs
On 4s the system would run hotter and have less runtime.
Why with more voltage and fewer amps systems usually run cooler. It will spin the motor at 48k rpm, but I wouldn't say that it is too high.
i was going to run the 2200kv but we got the 2650kv combos in work today so i decided im just going to go with that one on 4s. that way i can control it on the track and its cheaper for batterys.
I ran a Tekno NEU 2200kv on 6000mah 25c 5s geared 13/46 in an SC8 and it had wicked acceleration, 27 minutes runtime and cool temps. SC8 will have the same gearing and tire size as an RC8, and it was heavier. This was all on a track in race conditions.
if i remember correctly the tray is 140mm long. and the batterys im using is 150mm long. so i plan on just cutting the end of the tray to make it fit a bigger battery.
i already know im going to have to modify it a little.
