Since I'am getting most of my info from this site
I would like to share the progress I will be making on my truck.
If you got anny idea's for my truck just let me now
this is my setup so far,
Wandere 20 9XL wiht a bk 9920 and a Ubec
Graupner loader Ultra duo 30-GRaupner +"Schaltnetzteil 13,8V / 20 A
And the german conversion kit
And i emailt Mike for the folowing hopups.
1xHPI aluminum shocks NR: A712
2xHBdiffcups NR:C8019
1xHPI bearing 8x16x5mm NR B085
2xspider gear NR: 87193
SOME SHIMING RINGS NR?????
1xHPI Heavy Duty 2-Speed NR: 87227
FLM Exteded tvp NR:FLM45100
FLM Servo plate kit NR:FLM45500
FLM Center skid plate NR:FLM45110
2XFLM Servo mounts NR:FLM46000
Brushless Heatsink
SOME electric plugs and other electric stuf thati will need?
If you are going to be racing, I'd recommend 40 series bowties, if you are just going to bash, I'd recommend Moabs or Big Joes. Tires can get up there in price, especially if you get the 23mm hex, ($30 for hexes, $30 for special wrench) but with that much power, you should really think about getting the 23mm hex, it might save you a stripped wheel or two.
