Need better connectors
Jabe
Need better connectors - 02.12.2009, 06:23 AM
I have two battery setup (parrel), i currently have 5mm bullet connectors, but those are too loose, after few jumps, another battery is loose (disconnected).
Is there any connectors that would have "lock" like tamiya-connectors, but rated for +100A current, deans-connectors i wont use as those are too loose also, so it eliminates traxxas-connectors also.
So im searching connectors that would have "lock" and are rated +100A, dont care if its single or "dual" connector.
02.14.2009, 05:34 PM
Locking battery connectors for those kinda currents dont really exist, atleast not small enough for r/c use.
Deans plugs and traxxas connectors are normally very tight, very rare that they would come apart.
Same is true of bullet plugs; take a small allen key and insert it into hole down the centre of the male connector, then wiggle it around to push out the pins slightly. It should be a much tigher fit into the female connector afterwards.
Only other thing I could suggest is to look at your wiring and shorten it where possible, as less wire = less weight & strain on the plugs...
Jabe
02.14.2009, 06:03 PM
I think i got problem solved, problem was battery racks that bend after few big jumps and so allowed battery to move, causing bullets to open.
I figured that its better to squeeze female connector, as i cracked one male connector trying to make it fit tighter.
