Lipo Battery Testing and Balancing
sikeston34m
sikeston34m's Avatar
Lipo Battery Testing and Balancing - 03.02.2009, 02:26 AM
There has been alot of talk about how manufacturers/distributors come up with their C rating.
Alot of talk about how it's not standardized, and about how there isn't an established set of guidelines that sets the standards for performance.
I plan on diving deeper into this and also intend to come up with my own array of test equipment.
On it's way to me is this:
http://www.tmenet.com/Xtrema_balancer.htm
I've never seen a balancer quite like this one. I plan on running it in "computer controller mode". So I got the usb cable, a balancer plug adapter, and will be downloading the control software for windows vista.
It's pretty cool because it allows the user to control and monitor the balancing process via computer. This is all fine and good, but that's not really what caught my eye.
At any given time, by pressing the "test" button, it will report individual cell status and begin to graph the results. Any given time, even when the battery is under a load through the discharge leads.
We all know a chain is only as strong as it's weakest link. The same goes for cells of a battery connected in series. This is where cell matching and Quality Control come into play.
I intend to come up with equipment to vary the amp load on the pack being tested and monitor/graph the results.
This equipment will be an ESC capable of huge amperage, probably a MMM, hooked to a servo tester as to be able to turn it up and down. The ESC will be used in brushed mode hooked to a, yet to be determined, load.
In this manner, The amp load can be varied and results graphed and recorded over a time span to a preset low voltage cutout.
I also have a charger that will show how many mah is returned to the pack when it is recharged.
One thing I really like about this is, each cell inside the pack being tested will be shown. This will really show a manufacturer's ability to match cells.
I know the entire subject of C rating is a matter of controversy. But what I intend to do is come up with a working list of test results for a number of different Lipo Brands.
Something like this would at least alert us of the quality we are getting, instead of what the label "says".
