Motor keeps loosening up on motor mount....
Motor keeps loosening up on motor mount.... - 03.22.2009, 08:42 PM
Having an issue w/the motor moving on motor mount. The screws are as tight as I can get them and the motor still slides away from spur. The screws are the correct length. This happened to me today several times...I would re-tighten and then 10mins. later it would back off again..by the 4th time happening, I had to walk away for a minute or else there would have been a crt.5 in pieces.
Are you guys using any lock washers of any kind.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
03.22.2009, 08:55 PM
I think I threw a set of star washers or lock washers on mine, I haven't had any problems!
I should do the same..thanks!
George16
Supermaxx
George16's Avatar
03.22.2009, 11:09 PM
Lock washers work wonders. I use them too.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
