Savage flux 4s and 25/44
samintrepid
samintrepid's Avatar
Savage flux 4s and 25/44 - 03.20.2009, 07:39 PM
With 6s you can run 25/44 but with 4s it is possible some one have try ?
Thank !
samintrepid
03.21.2009, 11:22 AM
I have try to install optional 25 tooth with stock 44 spur gear and the motor side robe on battery box too tight impossible to install.
03.21.2009, 11:35 AM
To answer your first question you can definately gear it up by using a larger pinion. However it will put more load on the motor and the batteries. So if you do gear up with a larger pinion keep an eye on the temperatures of the motor and the batteries.
HPI really need to issue a new manual indicating how to correctly regear the flux... Nothing special: larger pinion = more load and more heat...
samintrepid
03.23.2009, 08:43 PM
I have run this weekend with 25/44 and 4S and the temps was 100F batterie, 86F motor and 118 esc after 20 min run.
Joram
Nitro?? BL rulezzz
03.24.2009, 03:31 AM
That are good temps!
What was the torque that the motor has now?
Greetz,
Joram
Standard is not an option!
  Send a message via MSN to Joram
samintrepid
03.24.2009, 08:41 AM
the motor are very powerful I don't see difference with torque 25/44 versus 20/44
fastbaja5b
fastbaja5b's Avatar
03.25.2009, 12:43 AM
What was the ambient temp?
Say Less, Do More.
samintrepid
03.25.2009, 10:54 AM
ambient temp was 50F
