medusa shaft moving
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
medusa shaft moving - 04.01.2009, 11:48 AM
Hello,
Today I changed the pinion for my 36-70-2300 motor then I discover this shaft moving about 2-3mm in and out is that normal?
Thanks
MMM v1 zippy 2x3s 5000mah neu 1y 1/8 diff's
MMM v3 Rc-monster 2x2s 5200mah-HC medusa 36-70-2300kv
Pic's - video - youtube video's
Jabe
04.01.2009, 03:48 PM
Check this, and make conclusion... You might want to check rear endplate first, that its on its place, if its ok, you should consider changing bearings or do some shimming.
I think there is mistage on Medusa's drawing, minimum end play should be 0,63mm and maximum 1,88mm.
Finnster
KillaHurtz
Finnster's Avatar
04.01.2009, 04:00 PM
At the worst, it could be a sign the magnet is coming off. I would check it all out before I ran it again to make sure everything is GTG.
