Originally Posted by Electric Eel
That is a tranny/motor forward chassis. It flips the motor and tranny around, and puts the motor next to the steering servo. The battery tray is in the back, but unlike the flm setup it has the entire width of the tvp to use for battery mounting. I will say this must be better balanced than the flm, but I would rather have the lipo in the front and the motor in the back. Given the amount of the wheelbase stretch, they should have a very large battery area to work with.
My version of the chassis (see stretched tvp thread) will have enough room to get a 160mm x 45mm pack in front of the tranny. The battery height will be a bit high, as the battery tray will also tie the top of the bellcrank posts together and serve as the servo mount. But MTs have higher cg anyway, and my truck is meant to be a basher. With a 15" wheelbase it should be plenty stable.
Look at all of the newer nitro truggies, they all have stretched chassis, and try to move the weight of the components forward to help steering on power, and jumping ability. Most of them just have open areas between the back of the nitro motor and the rear bulkheads...
