BMW M Power!
Thinking of getting a second charger (to be my primary), recommendations? -
05.29.2009, 12:25 AM
Hey all, right now I have a Hyperion LBA10 Balancer (6S capable) with an ICE charger (only 4S capable).
Before, this was plenty when I would run my E-Maxx, then after, G2R on just 4S. I could still charge the packs as one.
However, since then, I have expanded my electric fleet to include my CRT .5 (which runs 3S, though occasionally I'll throw a 2S pack in there), and I have a 1/16 E-Revo VXL pre-ordered, which I plan to run a paralleled set of 3S packs. And I have since upgraded my G2R to run on 5S and 6S.
So, between all those trucks and battery configurations and my charger's 4S limit, charging takes a long time, which leaves field charging almost a non-option.
So, it leaves me wanting a second charger.
Here are my requirements.
First off it must be quality! I don't want to buy a $15 dollar charger only to have it ruin my FlightPower packs. Under the circumstance I want to charger my two 3S packs in 6S, that's 360 dollars in packs being charged.
Second, it must do 6S at 4.5A so I can charge my G2R packs as one.
Lastly, I'd like it to be a balance charger to simplify things, but if not I will likely buy a FlightPower balancer to go with it (unless you have a balancer to recommend with the the charger, then please do so).
Thanks everyone!
BP
05.29.2009, 12:27 AM
Sounds like a 610i or 720i hyperion would be the best bet. I have 2 of the 610i chargers and would recommend them to anyone.
BMW M Power!
05.29.2009, 12:29 AM
I forgot to ask...
Would this be a charger that I could trust my FlightPower packs to or no? Seems a bit on the cheap side...but you never know.
http://www.hobbycity.com/hobbycity/s...idProduct=7523
Linc, where can I get those chargers? Only place I know of is Crap Amps...I'd rather not support them. They get enough money from the noobs.
05.29.2009, 12:42 AM
Mike has a bunch of them:
http://www.rc-monster.com/chargers.php
Including the one lincpimp mentioned. I think the 610I DUO is the ultimate charger. Although steep in price, I don't think you even need a second charger if you have one.
05.29.2009, 12:49 AM
Sell the ICE and the LBA10 and get something with a built in balancer... You can get around 70-85 bucks for the ICE and 25-30 for the LBA 10. I did this a while ago, sold my ice and 989 charger sand went hyperion. I have 2 610i and 2 1210i chargers... Plenty of options!
BMW M Power!
05.29.2009, 12:55 AM
Does the Duo do 6S per side?
05.29.2009, 01:01 AM
Yes. 180 watts of power per side, as long as you have a double extra gangster power supply...
180 is getting kinda close to the 6s at 4.5amps you want. I would want the charger to do at least 5amps at 6s, which is why I bought the 610i non-duo as it can do 250watts. And 2 of them was not much more than the duo...
BMW M Power!
05.29.2009, 01:24 AM
I don't think so linc? 4.5A x 6 x 4.2 = 113W. Far from it, in fact.
Hmm...time to put the ice up for sale when I get home...
05.29.2009, 01:35 AM
Nothing is 100% effecient. Try factoring 80% effeciency in and it starts getting close...
180 x .8 = 144... Getting closer than I like but if it is ok for you, then go for it!
Keep in mind that you will need a power supply that can output a bare min of 360 watts, at 14v (most hobby power supplys are putting out 14v or so) that is 25amps, but factore in the magic 80% and you get 30+ amps necessary.
I use modded server PS, that are good for 40+ amps at a little over 12v. I have 2 to serve the 4 chargers with a combined potential of 860 watts...
05.29.2009, 01:25 AM
I'd recommend the 720i also. I have it and it works like a charm. 250watts as well, 1-7cells, 20amp max charge, built in balancer. Beautiful charger!
05.29.2009, 01:38 AM
the duo will do a 6s at 5amps on each side, ive done it, make sure you got a hell of a PS because the 30amp unit we were using crashed afterwards...
but agian anything other than hyperion is just about sub-par these days, once you get a hyperion nothing else compares....
05.29.2009, 01:42 AM
And thats an understatement.....
But like mentioned, make sure that your powersupply is up to snuff as well.
05.29.2009, 02:01 AM
This is true, I have used most of the decent chargers available, and hyperion is my choice. I have about $450 in chargers and 60 in $PS (hehehe)
BMW M Power!
05.29.2009, 01:50 AM
Yeah...those are some insane power supply needs. What about a regular computer power supply? Like this one:
http://www.newegg.com/Product/Produc...82E16817139005
It's really cheap and has a 52A output on its 12V rail. I think that would be MORE than enough. I don't think I'll ever actually ping the 360watt maximum anyway, but this should be plenty if I do.
Has anyone ever modded a CPU power supply? I probably should be opening her up and soldering some bigger gauge wires onto the 12V output huh?
I'm thinking I might just go ahead and keep my ice. It'll be a good back up charger.
But I do need to get rid of some other crap I have lying around...
05.29.2009, 01:55 AM
Something doesnt sound right to me. I have quite a few computer powersupplies laying around. All of them have higher amp ratings at lower voltages. The 12V rating is the lowest amp rating on all +. But this supply, 12+ is the highest amp rating. But I may be wrong...
Most computer supplies are good for 10-12+/- amps. Not enough for most Hyperions...
