MMM 2200 on 6S with 3905 Emaxx and zippy 5000mah 20C cells
hemiblas
hemiblas's Avatar
MMM 2200 on 6S with 3905 Emaxx and zippy 5000mah 20C cells - 05.23.2009, 01:13 PM
I just thought I would post some numbers with my emaxx 3905 geared with the green Castle 18t pinion on the stock 68T spur. With some zippy 20C flightmax 3S lipos in series to get 22.2V. I know there is a lot of zippy bashing out there but I was pretty impressed. According to the Brian G's calculator I'm geared for about 50mph which should be a nice top end. With my basic wattmeter I got 80A peak with 11.11V on the volt dip. This was done after 3 or 4 passes. Again, this was just some informal testing. The cells were probably 80-90 percent charged when I tested them. If you guys have any questions shoot away, but this seems like a nice 6S alternative for the emaxx and the cells will fit if you loosen the screws on the battery hold downs as they are 51mm or so in width.
