Maxx Adapters for E-Pede
skellyo
skellyo's Avatar
Maxx Adapters for E-Pede - 01.25.2006, 06:37 PM
I've read a lot on here and various other places regarding using the Maximizer Products adapters to put Maxx wheels on a Stampede. However, the Maximizer adapters are designed for the Nitro Stampede, correct? It looks like the Nitro uses 5 x 11 x 4mm bearings whereas the Electric uses 5 x 8 x 2.5mm bearings...is this right? So would one need to change the spindles out to the nitro version or simply get 5 x 11 x 4mm bearings?
Thanks,
Sean
Rcbros
Rcbros's Avatar
01.25.2006, 09:53 PM
I use them on my E-pede and it did not require any modds
  Send a message via Yahoo to Rcbros Send a message via AIM to Rcbros
MetalMan
MetalMan's Avatar
01.25.2006, 10:02 PM
You could do the front steering to the Nitro version, that's what I did to my Rustler. It's a much smoother setup than stock, and steering is actually increased with the Nitro version.
coolhandcountry
coolhandcountry's Avatar
01.25.2006, 10:26 PM
What do you have to do for that metal man? I may do this if it works better.
MetalMan
MetalMan's Avatar
01.25.2006, 10:31 PM
It's detailed under "Nitro Rustler caster block & spindle conversion" here:
http://www.ultimatetraxxas.com/rustler_phase3.html
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.26.2006, 05:45 PM
I also carry the wild dagger adapter(when someone orders the adapters, I clarify if they have an electric or nitro pede). The WD adapters have 4 hexes and work on the electric pede with the addition of some spacers(which I also throw into the package when they are ordered). If you have an electric pede and order the adapters from me, I will make sure you get what you need to make it work!
