mamba max problem
mamba max problem
jlustig83
Brushless is the future now!
mamba max problem -
06.07.2009, 04:53 PM
This on and off switch wire worked its way off my mamba max. Should i take my chances and solder it? Or can i solder the leads on the circuit board together so its always on when i plug the battery in?
jlustig83
Find all posts by jlustig83
2
big greg
06.07.2009, 05:06 PM
i just take the wires off and put a little dot of solder on the 2 curcuits
big greg
3
bdebde
That's All Folks!
06.07.2009, 09:34 PM
Any soldering on the circuit board will void the warranty. If you're not worried about that, then solder away.
Ve8 - MMM, Neu 1509/2.5y, 6s
D8T - MMM, Neu 1515/2.5D, 6s
Muggy - MMM, CC 1520/1Y, 6s
SC10 4X4
bdebde
Find all posts by bdebde
Linear Mode
Switch to Threaded Mode
