Closed Thread
High End Brushless DNA Axial Comp Rock Crawler ARTR
pthunell
High End Brushless DNA Axial Comp Rock Crawler ARTR - 06.23.2009, 03:47 PM
This is an amazing complete ARTR Competition Rock Crawler that was built using the best high quality components available. Every part was picked to create the most ultimate crawler that money could buy. The DNA CFX Slingshot chassis is one of the best designs available and is made out of ultra strong and light carbon fiber. The Novak Goat Brushless System is ultra smooth and has the power to get the truck out of the tighest spots. It will do an amazing 14 mph as it is currently setup. The 2000mah lipo provides enough power to run the truck for about 45 minutes. The drive train of this truck has been made ultra strong with high strength steel gears and drive shafts. You won't be popping drive shaft pins on this truck.
This crawler is in excellent shape and has normal scratches on the bottom. It has very little use only having competed in 4 local comps. It moves across the rocks like a snake and is impressive to say the least. This is a complete truck. The only thing that you need to start crawling is a transmitter and receiver. Here is a list of the parts used for the built and links to where everything was purchased. If you click the links it will open up a page for more information and an online price.
DNA Slingshot Carbon Fiber CFX Chassis Kit = $179
Novak Goat Crawler Brushless System = $199
Axial AX10 Locked Transmission Set = $40
DNA Bolt on DIG w/ Steel Gears = $85
Hitec HS-225MG Mighty Mini Metal Gear Ball Bearing Servo for DIG Unit = $30
JR Z8800T Digital Hi-Torque Surface Servo = $110
Axial AX10 Locked Axle Set = $80
RC4WD Steel Extended Punisher Drive Shaft = $80
Traxxas Hard Anodized Teflon Coated GTR Shocks = $63
Traxxas Spring set = $10
DNA Aluminum Assassin 2.2 Beadlock Wheels = $99
Panther Cougar Crawler Tire w/Soft Foam = $30
Axial Aluminum C-Hub Carrier = $35
STRC Axial Aluminum Lock-out and stainless steel driveshaft kit = $46
STRC Precision CNC Machined Aluminum Steering Knuckles = $26
STRC Axial AX10 12mm Aluminum lock-pin Hex adapter set = $13
7.4 volt - 2000mAh 20C LiPo Battery Pack = $45
Traxxas Revo Large Rod Ends w/Hollow Balls = $15
JConcepts Rock Steady – Crawler body = $22
Micellaneous Items - Lead weights, Novak Glitch Buster Capacitor, Custom Delrin rear skid plate, etc, = $50
Total Spent = $1257
That covers about everything. I'm sure that I'm missing a few items. I am selling it because with two jobs and 3 kids I don't have time for RC anymore. Thanks for looking and feel free to ask questions. PM for Price
Closed Thread
