E-revo rebuild...getting ready.
GoldenRevo
E-revo rebuild...getting ready. - 07.29.2009, 09:05 PM
Hi all,
Well I think I am nearing the end of ordering parts for my e-revo. As you might remember it has a brand new MMM 2200kv and ESC in it and is currently suffering from a wrecked slipper.
Ordered Parts
Traxxas Turnbuckle Rear Red 49mm 3738
T-MAXX 3.3 Pivot Ball Cap Dust Boots Traxxas 5378X Revo
Dynamite part # DYN2534 Servo Arm
PRO LINE 6037-00 Alum Steer Arm
Variable Damp Kit GTR KiT 5461
HD Servo Saver Spring 5344x
P2 Rockers 5358
Red Pushrods (2) 5318x
Red Tubes (2) 5338r
Center Diff Trax #5614
Diff cup with the metal side plates #3978
Single Steering Servo JR z9100T
Extended Rear Wheel Arm TRA5333R
Sway bars Tekno RC Sway Bar Kit #tkr1013
Traxxas Sway Bar Kit
Springs - white- F green -R or orange - F gold - R
Revo Slip Press Plate & Hub TRX5351
Jato Shock Boots (2) TRX5464
Slipper Rebuild Kit Revo/Maxx TRX5352X
Jato Spur Gear 0.8p 56T TRX3957
Ball Bearings 5x11x4mm (2) TRX5116
Castle-Link USB Programing Kit CCRPHXL
Proline - harddrive - custom painted
JConcepts Rulux 1/8 Trk Whl 1/2 Offset Half-Ups Wht (4)
Pro-Line Crime Fighter LPR
Pro-Line Badlands MT Tire
Axial Wicked Retro 5-Spoke MT Wheel White
OFNA Diff Lock OFN10230
Racers Edge Locking Putty (used to thicken up the Ofna diff lock)
Losi Diff Oil 20 K & 50K
Losi Shock oil - 60
6 - SMC 6000mah hard case 28C
Other things I am considering purchasing.
Tekno RC Axle Carriers and 17mm Adapters tkr1014
Acer Racing Ceramic Nitride Pro Series Bearing Kit
Traxxas CV Style Stub Axle Kit TRA5654
Traxxas Half Shaft Set (Plastic Parts Only) (Long) (2) #5656
Traxxas Differential CV Output Drive Kit #5653
GH Racing Aluminum Pivot Ball Cap (4 PCS) GHH02286
Xtreme Racing Traxxas Revo Black Carbon Fiber Rear Tie Bar XTR10413
Rpm rear tru-track
Front rpm a-arms
I will be running this setup.
56/18 gearing
Single Steering Servo: JR z9100s
50k/750k/20k f/c/r fluids
#3 pistons with 60wt oil ( orange and gold springs) or (white and green)
2mm spacer below the front bump stop
Ride height 45mm front and 50mm back
traxxas black sway bars rear
teckno sway in the front
long wheel base arms
crime fighters m2 lpr
rulux rims 1/2 offset rims
steering mods done
pushrods: front - outer, rear - middle
P2 Rockers
Bump Steer Rear: Mid
Bump Steer Front:Upper
Opinions?? Anything in the considering to purchase list that is a got to have? What would be the best upgrades from that list?
Thanks
Chris
