Just got a used Mini T the thing will have the throttle stick and keep going out of controll has a mamba motor and speed controller and losi rx and tx. Batterty light in controller is green and both antennas up? Is this a common problem do I have a liquid dammaged reciever?
__________________
I would say reset the esc and reprogramme the radio to it, paying attention to the throttle trim and what-not. After that, check the tx batts are fully charged/ fresh, and that there are no loose or damaged connections (or antenna damage). Beyond that =
Could be a bad esc... same problem happened to my old brushed 18t controller after going thru a puddle. If your steering works fine it leads me to believe it's not the rx...
